04-25-2012, 04:16 PM
#1
bottom of tub & shower flexes
The bottom of both our shower tub and shower flex a bit in spots when we walk on them. The shower is a one piece surround, and the tub is fiberglass, I believe.
Is this common? Are the bottoms thin fiberglass laid over studs? We recently bought this condo, I've never experienced a tub or shower where the bottom flexes like this.
04-25-2012, 10:57 PM
#2
Not suppost to move at all, at some point it's going to start cracking.
There made two differant ways, self supporting and set in a bed of morter.
04-26-2012, 07:46 AM
#3
What he said, fiberglass tubs/shower either require support during installation or they are built in such a way that they don't. Yours does need additional support, but did not get it when it was installed. If there is access to underneath, even if you have to open some drywall, expanding urethane foam will usually give adequate support. Fill the cavities between the subfloor and tub floor.
04-26-2012, 02:28 PM
#4
When applying the expanding urethane foam, is there any chance of the tub/shower floor bulging up due to foam pressure? Are there any precautions to take when doing the job?
Thanks,
HRG
04-26-2012, 09:56 PM
#5
not suppose to move or flex.....sounds like damaged unit.....or maybe a bad install...
04-26-2012, 10:48 PM
#6
Persona Non Grata
Thanks,
HRG
Fill the tub with water.
Reason: Stoopid sounding sentence.
The Following 3 Users Say Thank You to VIPlumber For This Useful Post:
04-27-2012, 04:07 PM
#7
Thanks,
HRG
There are also low expansion foams available.
The Following User Says Thank You to goosebarry For This Useful Post:
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
