Bottom Drainage From Brand New Water Heater Is Dirty... - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-01-2010, 06:38 PM   #1
Seasoned DIYer
Rewards Points: 150
Bottom drainage from brand new water heater is dirty...
I replaced an electric water heater. After it was filled, I opened the bottom drain under pressure to flush out junk that might be in there at the time of installation. It wasn't as clean as cold water, but wasn't too bad.
Few weeks later, I let out a few gallons for testing and its already disturbingly dirty.
Hot water that is pulled from top through faucets looks clean.
Picture compares cold water that is supplying the water heater and water drained from bottom spigot.
What is the brown stuff and where did it come from? I understand accumulation of crud with time, but this thing is less than a month old!
On the left is incoming cold water, on the right is water drained from the bottom spigot.
HVAC_NW is offline   Reply With Quote
Old 11-02-2010, 06:24 AM   #2
Rewards Points: 1,216
Might be settlement from when you installed it. try running more out into a drain and retest. Are you on well water?
COLDIRON is offline   Reply With Quote
Old 11-02-2010, 07:01 AM   #3
Rewards Points: 1,538
Did you have this same issue with your previous water heater?
Maybe your water supply is inherently sediment laden. Not enough to see in the incoming cold water on a gallon for gallon basis but enough to collect in the tank after several tankfuls are used. Coarse enough that it settles to the bottom but fine enough that it comes out looking like colored water rather than sandy water. If this keeps happening you will need to drain a gallon or so from your water heater every month (from the looks of the bucketful I think you could go 3 months at a time).
Old 11-02-2010, 03:23 PM   #4
Seasoned DIYer
Rewards Points: 150
Looks like its time to change out the scrap plastic spigot with brass ball valve before it has the chance to become brittle then.
I'm not on well water and water in my area is considered soft.
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Water heater drain mechanism (10 year old) guptaalok Plumbing 1 01-02-2009 05:40 AM
Leaking Rheem 60 gal Electric Hot Water Heater aklkuno1 Plumbing 3 10-22-2008 10:13 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Water heater problem bear1957 Plumbing 23 11-01-2007 03:53 PM
