Boring Studs For Sink Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-10-2011, 08:41 PM   #1
Rewards Points: 89
Boring studs for Sink drain
Prefabing partition walls for my basement project,one of the jobs I wish to do is to prebore the studs for the lavatory sink drain before I assemble and erect the wall.
My question is,does there exist a rule of thumb for height of holes in studs in relation to height of the bottom of the sink.
Should it be 2 inches,4 inches,or a different number lower than the sink bottom?
I know I must pitch the holes 1/4 inch every 4 feet for proper drainage.
spring3100 is offline   Reply With Quote
Old 12-10-2011, 09:12 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
id say to rough in the center of pipe in the neighborhood of 17" where it turns out of wall .
depending on how far you are from the stack youre tying into 1/8"-1/4" per foot would be a much better number to aim for.
id drill the holes after wall is up,much easier to line things up that way.
dont forget the holes for vent line higher than level of sink
plummen is offline   Reply With Quote
The Following 2 Users Say Thank You to plummen For This Useful Post:
oh'mike (12-11-2011), spring3100 (12-10-2011)
Old 12-10-2011, 09:19 PM   #3
Rewards Points: 175
18" inches from floor board is my rule of thumb is where i put my stub-out/hold rite but may differ by lave you just want the lines to reach from angle stop to faucet. also i go 1" every 4 ft "just to be safe"
(and remember hot is always on the left
Licensed plumber!
plumbing is offline   Reply With Quote
The Following User Says Thank You to plumbing For This Useful Post:
Old 12-10-2011, 09:25 PM   #4
Rewards Points: 582
I would drill holes after the wall is built vanity drains can be 17-19" off finish floor to center of outlet.
The Following 2 Users Say Thank You to ben's plumbing For This Useful Post:
Old 12-10-2011, 09:47 PM   #5
Rewards Points: 89
Thanks for you prompt replies.
FYI,this drain run will be about 4 ft,then it will 90 and run about three or four feet into a Saniflo tank.
I will put a cleanout connection on the 90,and either an AAV or connect to the common vent.
I will post pictures as the project progresses.
Happy Holidays to all.
I clog my bathtub drain with hair-solution works for me gailquilter2 Plumbing 6 07-02-2012 08:20 PM
I clog my bathtub drain with hair-solution works for me gailquilter2 Plumbing 7 08-22-2010 10:11 PM
Bathtub Drain -- Without Overflow Waste Trap sabinh Plumbing 6 02-15-2010 10:24 AM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 10:52 PM
Washer drain peloncito Appliances 7 08-04-2007 12:56 AM
