Booster/Transfer Pump Brand/Model Recommendations? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-17-2012, 12:27 PM   #1
I need two pumps that will need to run from a 9000 gallon water tank already fed by a well pump. One must be at least 60psi at 40gpm. It doesn't have to be potable. The other should be about 60psi at 25gpm for potable water. Any suggestions for brand and model? How about web sites or what kind of stores to look in locally? I'd prefer local, actually.
Thanks!
jsimon7777 is offline   Reply With Quote
Old 11-17-2012, 12:36 PM   #2
Since your profile and your post don't mention where you are, it will be difficult to recommend local sources...
Evstarr is offline   Reply With Quote
Old 11-17-2012, 12:50 PM   #3
Hah, sorry. Castro Valley, CA.
Sump Pump Questions henlij Plumbing 22 03-16-2015 10:00 PM
replaced flooded convertible jet pump, pressure will not go over 30 lb. dcreech Plumbing 4 09-18-2011 10:14 PM
Sump pump help jazzyj Plumbing 10 09-12-2011 07:55 AM
Recommendations On A Small Pump For Water jte1130 Tools 3 09-26-2008 09:50 AM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 09:36 AM
