Booster Pump Gurus Please Take A Look - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-17-2014, 01:01 AM   #16
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Originally Posted by Craftybigdog View Post
How come with the technology age we live in they don't have digital pressure switches.
We do, they just cost more than your first born child, and usually are used in conjunction with a variable speed pump.
Journeyman Plumber
Old 01-17-2014, 01:03 AM   #17
Doing it myself
Alan's Avatar
Thanks so much guys for your inputs it really makes sense.
I know when I first installed the booster pump in had the flow switch on it. It worked great, you could take a shower with real nice pressure. Then the flow switch went and I installed the pressure switch and it was never the same. So at the point with several things running I don't believe flow was a problem. Nothing ever cavitated. As for the filters they installed I have just changed them on a regular basis. I will check psi settings.
Also : If you changed the flow switch, and it isn't working anymore, chances are, it needs whatever switch was on there, rather than the pressure switch you replaced it with. What kind of pump is it?
Journeyman Plumber
Old 01-17-2014, 08:12 AM   #18
It's a harbor freight model.
Craftybigdog is offline   Reply With Quote
replaced flooded convertible jet pump, pressure will not go over 30 lb. dcreech Plumbing 4 09-18-2011 11:14 PM
Sump pump help jazzyj Plumbing 10 09-12-2011 08:55 AM
Sump pump jerks when it turns on Sparkastic Plumbing 3 08-25-2011 07:51 PM
Reconnect a Replaced 3/4 hp motor on Polaris pool booster pump - gekunkel Electrical 1 10-08-2010 05:12 PM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
