Boiler Wont Heat House - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-28-2011, 12:10 PM   #1
Boiler wont heat house
Hi my new boiler was put in with the pump at the return of the water. it pumps the water into a manifold pipe that has all the in and out water on the same pipe. would that pump not pump the cold water into the furnace and then they have a valve that shuts it down so it has tie to heat up in the boiler. does anyone have any advise.
donna patrick is offline   Reply With Quote
Old 01-28-2011, 12:22 PM   #2
Experienced
Jackofall1's Avatar
Donna, some pictures of your system would be extremely helpful with this question
Old 01-28-2011, 05:40 PM   #3
Rewards Points: 1,216
What seems to be the problem with the system?
COLDIRON is offline   Reply With Quote
Tags
boilers
Hot water boiler furnace-insufficient heat Nashman HVAC 2 11-06-2011 06:15 PM
Circulator pump - old vs new (boiler unable to heat home) saturn78 HVAC 1 11-01-2010 04:45 AM
Governments Renewable Heat Incentive SMurray Green Home Improvement 1 10-24-2010 08:30 AM
Boiler one zone call heat but not fire up Ballastar Plumbing 6 02-12-2010 11:17 PM
Boiler - Pex vs Copper - Heat Exchanger AndrewF HVAC 9 01-22-2010 11:23 PM
