Boiler Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-04-2010, 02:26 PM   #1
Boiler Pressure
My boiler is running about 12-14 psi. I have three floors, counting the basement where the boiler (weil-mcLean) is.
I recently removed one of the baseboard radiators from the middle floor and probably introduced some air in the system, but the pipes are not noisey and I am getting heat throughout the system.
If I do need to add water to increase the pressure, how do I do that? All of the valves around the boiler are already open...I don't know how to increase the pressure. There is an air purge tank (I think that is what it is called anyway), and it is hot on top and luke warm on the bottom, so I assume it is working.
yukonken is offline   Reply With Quote
Old 12-04-2010, 06:42 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 594
Ayuh,... 12 to 14psi is fine,... You probably have an auto-fill valve, they're usually set for 12psi..
'course, that's 12psi Cold,... it'll run at slightly higher pressures...
Do you have bleeds at the top floor radiation,..??
If there's trapped air, that's a good place to look...
Old 12-06-2010, 01:41 AM   #3
Rewards Points: 150
Bleed them
Bleed your radiators... Sounds like an air Block somewhere. I usually start at the one closest to the Boiler and work my way up... others go right to the top both methods work
Docwhitley is offline   Reply With Quote
Tags
boiler
leaking pressure relief valve on heating water boiler benjamintr HVAC 13 01-29-2011 06:32 AM
Leaking Pressure Relief Valve of Boiler rob07030 Plumbing 2 11-02-2010 08:11 AM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 07:03 PM
Hydronic boiler pressure question. RickInMissouri HVAC 1 01-23-2010 05:57 AM
too High boiler pressure beacu Plumbing 2 10-18-2008 12:52 PM
