#1 |
Boiler one zone call heat but not fire up
I have an 13 years old super hot boiler, only 2 zones.
zone 1: 1st floor heat zone 2: 2nd floor heat If Zone 1 works fine. zone 2 not If Zone 2 works fine. zone 1 not If zone 1 works fine, When singly turn zone 2 on, I can hear the click sound from boiler, and the 2 circulator pumps water, but the boiler not fire up, if now turn zone 1 on, the boiler will fire up just about immediately. Any ideas on what I could do to fix this? Thanks! |
#2 |
Do you get enough heat in zone 2?
Sometimes the zone and the burner are wired and configured to operate independently. When the water temperature in the boiler gets too low then the burner comes on. This configuration could have resulted if the system was originally one zone and the second zone added at a later date. If zone 1 always turns the burner on, then there needs to be an overlimit switch to turn the boiler off if the water gets too hot. A possible disadvantage is that zone 1 might be forced off before the room temperatures are reached.
The average homeowner who lost his house in the Oklahoma tornadoes should move for good and not rebuild. Too much complexity watchdogging the contractor. Too much a chance to be defrauded. Last edited by AllanJ; 02-11-2010 at 08:49 PM. |
#3 |
Thank you for your answers,
Yes, zone 2 is no heat, but zone 1 can reach the temperature I set. the 2 zones setup in one sametime. I noticed the water out temperature is always high, like 180F, if this is the reason, how can zone 1 can fire up in this temperature? Last edited by Ballastar; 02-11-2010 at 10:59 PM. |
#4 |
If you turn up the thermostat for zone 2 and turn down the thermostat for zone 1, does the burner come on sooner or later? At what temperature?
The average homeowner who lost his house in the Oklahoma tornadoes should move for good and not rebuild. Too much complexity watchdogging the contractor. Too much a chance to be defrauded. |
#5 |
Licensed Master Plumber
You probably have a L8124 or L8148 dual aquastat that has a relay for the zone 1 circulator and for the oil burner also. The second zone is probably wired to an 845 relay that should have been powered by ZC or the 8147 (24) 180 is not awful high for the temperature to be. You can get the wiring from www.taco-hvac.com
Always ask to see your contractors license! |
#6 |
Thank you all
![]() Now the 2 zones works, a new question comes, everytime turn on the thermostat, it need all most 3-5 mins the boiler fires up, is it normal? |
| Display Modes | |
| Bathroom Floor Heat options | bmac1967 | HVAC | 1 | 01-30-2010 04:49 PM |
| Adding new zone | makapacs | HVAC | 0 | 11-26-2009 01:35 PM |
| help with third heat zone i just put in... | wombosi | HVAC | 6 | 04-21-2009 01:02 PM |
| Cracked Heat Exchanger | SusanB. | HVAC | 12 | 10-14-2008 04:57 PM |
| Is it normal for a Heat Boiler shuts off and on? | gforce | HVAC | 1 | 11-12-2007 11:36 AM |
