Boiler - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-05-2013, 03:24 PM   #1
boiler
j have a ferroli F28 boiler and it's flashing F in the display panel and not heating, what can I do?
zoeylou is offline   Reply With Quote
Old 01-05-2013, 03:42 PM   #2
I've never worked on a Ferroli boiler, but I found this on line: http://www.ferroliservicecare.com/do...F28%203540S920[1].pdf
The first thing with any boiler that has stopped working is to make sure there's water pressure in the system. Should be anywhere from 10 to 20psi (+/-).
If there is water pressure, AND gas in the tank, go ahead and hit the reset button on the control module and see what happens. If it fails again, refer to the troubleshooting chart on the document I provided a link to. I looked, but didn't see any "F" error code; should be "F" plus a two-digit number.
Ishmael is offline   Reply With Quote
Suspect Electric boiler causing brownout crankcase Electrical 4 11-06-2012 01:41 AM
New Boiler for an Office - Got Two Quotes, but What Do We Need? Prolow Plumbing 0 09-17-2012 06:10 AM
Setting the reset "Curve" for a modulating boiler (modcon) mknmike HVAC 5 02-10-2011 11:37 AM
Need help fast please re hydronic boiler water supply and backflow DanDaMan HVAC 6 12-11-2010 02:26 PM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 06:03 PM
