Hello all! I am wondering how to blow out a water line that is not used with a sprinkler system. I have searched and the instructions are for sprinkler systems, and I guess it would be almost the same, so here is my setup.
I have a separate spigot on the back of the house that ties into the original one next to it, which is insulated and ok. The spigot when turned on runs water out about 100 feet or so to a tree in the back part of my back yard to a spigot attached to a tree.(big yard) A few feet before the tree, the water line breaks off left and right, like a "Y" to a shed I have on the left side of the yard and another on the right side, also going to spigots attached to the side of the sheds.
The distance to each shed where it y's off is about 50-60 feet or so. So basically it is a dedicated line that goes straight out and y's off. Do I just hook up an air compressor and blow out the line for a few minutes? I do not think this should be too dificult or as involved as doing a sprinkler system. Also, what kind of connection do I need to put onto the compressor to attach to the spigot? Thanks for your help! Mike.
