Blockage In Leaching Field - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-24-2012, 12:34 PM   #1
Blockage in Leaching Field
The holding tank fills up and I am having a puddle of water seep up from the leaching field near the distrubution tank. Does this mean a blockage in the distrubution tank? How can this be checked without tearing up my whole yard?
Gilly04 is offline   Reply With Quote
Old 03-24-2012, 12:39 PM   #2
Civil Engineer
Rewards Points: 4,860
I assume you mean the distribution box, which is a small box at the head of the leach field, typically concrete or plastic. If you can find the distribution box, it should be easy to dig up, and since it is small, it will not do much damage. That would be a good place to start checking what the problem is.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
plummen (03-24-2012)
Field Stone and Mortar Wall, will it be stable? NorskeDiv Landscaping & Lawn Care 4 07-14-2011 10:18 AM
location of new septic field rkibler Plumbing 5 10-05-2010 01:55 AM
Septic Tank not flowing into leach lines or drain field michaelschier Plumbing 19 09-01-2010 07:58 AM
How do i fix/install septic tank drainage field? vcordon Plumbing 10 06-15-2010 10:20 PM
Septic Drain Field ekulrenlig Landscaping & Lawn Care 16 04-27-2010 09:59 PM
