Blockage In Kitchen Water Line. - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-18-2009, 08:47 PM   #1
Blockage in kitchen water line.
I installed a new kitchen faucet recently. While doing it I replaced the lines it with braided stainless ones, put in new drains, new line to the dishwasher, and installed a boiling water on demand tap. It all worked out beautifully, and I was very pleased with it.
Until three weeks later. We spontaneously stopped getting hot water on that tap. Cold water pressure is fine, but not the hot water. To fix this I replaced a bottlneck that was flexible pvc on the inlet pipe with something more significant, and I also pulled everything on the hot end apart, and checked it for blockage. Didn't see anything, so I put it all back together.
Pulled it all out again, and this time took the sprayer hose line off, and noticed a chunk of corrosion wedged in there. Score!
BUT, it still wasn't fixed. There's a block somewhere between the valve and the place where the hot & cold water combine. (I checked that I was getting water at the valve). It's not the big line going to the faucet, which was very open and clear. It's something else. What can I do to find and remove the block, or at least fix it?
Local Yokel is offline   Reply With Quote
Old 03-18-2009, 08:56 PM   #2
HVAC / Plumbing
You will have to Disassemble the faucet.
kenmac is offline   Reply With Quote
Old 03-18-2009, 09:12 PM   #3
From the topside?
Old 03-18-2009, 09:36 PM   #4
HVAC / Plumbing
I would take it out & take it apart Must be some scale logged in side some where If you had no issues b-4. Do you have galvanized water pipe ?
Old 03-18-2009, 09:43 PM   #5
I would take it out & take it apart Must be some scale loged in side some where If you had no issues b-4. Do you have galvanized water pipe ?
Yes. The pipes that I can see are galvanized steel, and it looks like there's some corrosion inside. I guess when I have a free evening, I'll pull everything back out again, and dissect the faucet.
Here's the faucet in question:
This is the old plumbing. Those look like galv. steel to me. I've since replaced the angle stops here (and the hot water one failed while I was working on it - would have been a disaster if I hadn't already had the mains off.
Old 03-18-2009, 10:24 PM   #6
HVAC / Plumbing
It has been my experence that when you do anything with old galvanzied pipe. Usually some of the corrosion breaks free & causes problems .. Usually in a faucet...By the way that sink ,counter top looks very nice
Old 03-18-2009, 10:34 PM   #7
Thanks. You should have seen the bright blue psychedelic countertop some soul put in there before us. Googling around trying to solve this issue, I've heard several warnings about the pipes. Now I know I suppose, though I don't know if I could have prevented this one.
Gray PCV for water supply line - is this OK? Jim S. Plumbing 13 08-09-2010 09:20 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
Water supply line replacement bamaknox Plumbing 2 01-08-2009 08:51 AM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-06-2008 11:31 PM
Replacing part of the Main Water line rgmetro Plumbing 2 04-12-2007 08:30 AM
