Old 10-29-2007, 01:49 PM   #1
bleeding your heating system
There is air in my heating system how do you bleed the system
jbperretta is offline   Reply With Quote
Old 10-30-2007, 09:24 AM   #2
First, you should have bleeder valves on your baseboards. Thei can usually be operated by a special square-drive key (about $1.50 at HD) or with a coin or short screwdriver. When water is circulating, you open them a bit, and wait for air to escape. When water starts coming out, close. Wait a minute or so, open again. If you open, and no air comes out, just water, move on to next section.
Also, depending on what kind of expansion tank you have, you might have a problem there. With an older type closed (or open) tank, some air will always get absorbed by water and then form bubbles in the baseboards. I would consider installing a FILL-TROL unit. It is a bladder tank precharged to 12psi, controlling a fill valve, and has an air separator and aoir vent. In one unit, it absorbs the pressure when system heats up, provides makeup water when needed, and eliminates air.
If you already have something like that installed, you might need to open the air vent cap a little. FILL-TROL will get rid of air trapped in the main. For air trapped in baseboard units, you still need to work their own bleeded valves.
scorrpio is offline   Reply With Quote
Bleeding a boiler system jpg HVAC 1 12-16-2008 04:53 PM
New To Hot Water Home Heating System Midicat HVAC 2 10-14-2007 09:12 PM
Bleeding my heating system 1-2-3 bwoo HVAC 25 01-02-2007 03:49 PM
Hot Water Heating System Estimate Cost ? helpless handyman HVAC 45 12-26-2006 10:59 AM
Need some serious advise on heating system helpless handyman HVAC 26 12-07-2006 06:28 PM
