Bleeding New Oil Supply Line Troubles. - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-23-2011, 11:22 PM   #1
Rewards Points: 150
Bleeding new oil supply line troubles.
Im having trouble bleeding a new supply run ( 3/8) for my beckett burner.
It's a brand new run, about 17'.
I've gone through the reset cycle about 15 times now, bleeder wide open, getting air - but oil never comes. doesnt seem to want to prime the line
Any tips or tricks that might come in handy so I can get this line bled and heat back on?
alecmcmahon is offline   Reply With Quote
Old 03-24-2011, 07:12 AM   #2
Rewards Points: 1,216
Did you check the filter cartridge case when you put the new filter in for air leaks and make sure it was full of oil before you started it??
COLDIRON is offline   Reply With Quote
Old 03-24-2011, 10:32 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,736
Ayuh,... Did you turn the tank back On,..??
Old 03-24-2011, 11:24 AM   #4
Rewards Points: 150
Got it, Apparently there is a pump prime mode on my becket afg.
Hold red button 30 seconds, green light will flash, let go... click repeatedly until burner kicks back on. you are now in pump prime mode.
the burner will run for 4 minutes instead of the 15-20 second lock out cycle.
leaky copper fitting in supply line for fire sprinkler system tina2435 Plumbing 5 09-18-2009 09:54 PM
Draining and then filling and bleeding system Nat1020 Plumbing 12 11-19-2008 11:29 PM
can I connect PB or Pex supply line to barb with clamp? grgryl Plumbing 11 08-20-2008 04:11 PM
Is it normal to change the upper line at the meter when running new supply line? twilightcall Plumbing 3 08-08-2008 11:10 AM
hot pilot light supply line dlkk HVAC 1 02-24-2006 05:45 PM
