Bleeding Hot Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-19-2006, 10:19 PM   #1
Question
hi,
i asked this before, but didnt need to replace the hot water heater after all. now, my gf's mothers hot water heater went on the blink, and i have to look at it in a day or so, so just in case i have to replace it. plz, tell me if this is the correct way to bleed the system. turn water on to heater, and at the same time have the hot water in kitchen sink turned wide open, watch til i get a steady flow of water, then shut off, check for leaks, and turn on hot water heater.
bob
bobo is offline   Reply With Quote
Old 03-20-2006, 07:23 PM   #2
jproffer's Avatar
Rewards Points: 702
I've always just went ahead with the replacement and then turned on hot water somewhere up high until I get a solid stream of water.
OK.....I just read what you wrote again, and come to find out I could have just said "yes":p ...but since I typed it, I'll leave it. What you said sounds good.
jproffer is offline   Reply With Quote
Old 03-28-2006, 04:11 AM   #3
Long-Time DIYer
Mike Swearingen's Avatar
Yes, that's the way to bleed air from the heater and the lines, but I would recommend running it through an unscreened tub or utility sink faucet rather than a screened sink aerator to prevent any stirred up debris from clogging it.
Mike
Mike Swearingen is offline   Reply With Quote
Electric Water Heater GTSRider Plumbing 31 12-07-2008 12:30 PM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
Chimney Liner for Water Heater mruggeri001 HVAC 6 01-10-2007 07:08 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
