Old 06-16-2010, 05:54 AM   #1
bleeding central heating system
Cant seem to drain central heating system, no water coming out of drain valve any suggestions.
mackie is offline   Reply With Quote
Old 06-16-2010, 12:42 PM   #2
You might need to open up a bleeder valve on the upper floor to allow air into the system. If air cannot get into the piping, then the water will not come out of a closed loop system. Is it baseboard hot water or radiators?
The Engineer is offline   Reply With Quote
Old 06-16-2010, 02:50 PM   #3
Thank you for your advice, will do as you say, fingers crossed.
Mackie.
old heating system jtb003 Plumbing 2 01-30-2010 09:48 PM
Severe Rust and Corrosion in Heating System C George Plumbing 0 01-15-2010 09:30 PM
Need advice for new heating system ASAP aok HVAC 9 02-18-2009 02:45 PM
Central Heating Problem BackBoiler488 Plumbing 4 12-30-2008 01:31 PM
Central heating help please!!! arif101 HVAC 3 10-19-2008 08:05 PM
