Old 12-11-2009, 10:56 PM   #1
bleeding a boiler system
I m not sure if the system has to be off or on when getting started
big fred is offline   Reply With Quote
Old 12-11-2009, 11:01 PM   #2
Xtreme DIY'r
Radiators ?
I have a hot water boiler system
I turn the heat down & then bleed the radiators
Old 12-11-2009, 11:51 PM   #3
GC/Master Plumber/Mech
Turn the gas off to the boiler and make a call for heat then bleed away
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 12-12-2009, 09:02 AM   #4
sdsester's Avatar
Bleeding the boiler of sludge and stuff or bleeding the system of trapped air? You probably need to tap the radiators of it is an air problem and I think the system needs to be one for that. Be careful though, don't get burned by the steam!
I find it handy to have a short garden hose ready and going to a drain, laundry sink, or whatever when flushing out boilers. Beats hauling buckets of disgusting crud. Do make sure the valve closes again all the way when you are done. Sometimes crap will get stuck if it is not flushed out all the way.
sdsester is offline   Reply With Quote
Old 12-12-2009, 09:08 AM   #5
Remodeling Contractor
This depends on if you have valves available to isolate the boiler from the zones. If you do then you can close these off after turning the gas or oil off to the unit. Then backfeed water into the unit and bleed out the air using the drain spigot. If you do not have this setup then you need to run the circulator in order to force water through the system to extract air. Bleed one zone at a time by closing all valves and only opening the two for the zone you are working on. Turn the thermostat to the highest setting to get the pump running.
Gas Boiler furnace or a new system? paulssn HVAC 1 08-29-2009 11:02 PM
Bleeding a boiler system jpg HVAC 1 12-16-2008 04:53 PM
Draining and then filling and bleeding system Nat1020 Plumbing 12 11-20-2008 12:29 AM
boiler / Over-pressurizing cparke HVAC 1 05-21-2008 06:54 AM
Bleeding air - Hot Water Boiler Dragon HVAC 10 10-30-2006 09:13 AM
