Bleeding A 5 Zone Boiler - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-18-2011, 08:48 PM   #1
Bleeding a 5 Zone boiler
I've recently had to drain my wood boiler to a level below where a former HW Coil was in order to replace the rubber gasket. Now I have air in the entire system. I have an automatic water feeder on a system which has 5 zones. What is the best way to bleed the air from this system? I have shut off valves on each zone so should I close all valves and proceed to open and bleed and close one at a time? If so where should the lever on the feeder valve be straight up or laying down?
If there is a better way to do this i would like to hear from anyone.
Happy2b
Happy2b is offline   Reply With Quote
bleeding hot water boiler baseboards kmwhite Plumbing 1 01-16-2011 08:55 PM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 06:03 PM
No heat in one zone: Need help bleeding system dvsrikanth HVAC 0 04-01-2010 08:55 AM
Boiler one zone call heat but not fire up Ballastar Plumbing 6 02-12-2010 11:17 PM
Boiler heating zone not working properly ssevern HVAC 5 12-19-2009 06:05 PM
