Old 05-08-2006, 11:27 AM   #1
Bleeder Valve Leak
hi,
the bleeder valve that serves to drain the pipe leading to an outside (hose) faucet during winter months is leaking.
is there a "quick fix: (e.g. - silicon tape) that may solve this problem, or does the valve need to be cut out and replaced.
we recently finished out basement and the small leak never was an issue, but now with the drop ceiling in place we need to seal this leak once and for all.
thanks for the help.
jwfran is offline   Reply With Quote
Old 05-08-2006, 09:12 PM   #2
Bleeder Valve Leak
Do you have the manufacturer of the valve?
Or can you post a picture of the bleeder valve?
Some have a small rubber gasket(washer) inside the bleeder valve cap and it just may need replacement. But I am not sure if you have this style of bleeder valave.
redline is offline   Reply With Quote
ball valve leaking bwall Plumbing 10 12-31-2012 08:25 PM
Toilet valve replacement? steve771 Plumbing 18 07-10-2007 11:50 AM
Main valve not working. Water won't turn on! skellies Plumbing 1 10-31-2006 03:17 AM
Water heater drain valve leak Fletcher33584 Plumbing 3 02-28-2006 08:07 PM
leaking 1 1/4" Brass Ball Valve creemore Plumbing 2 03-11-2005 09:23 PM
