Bleed Valve On Hose Bib - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-15-2008, 12:58 PM   #1
Bleed valve on hose bib
I turned off the water to the outside and opened the bleed valve in the house. Only a few drops of water came out. This would certainly NOT empty the line to outside. Do I need to do something to pull the water out of the line? Can I use air pressure outside to push the water out the bleed valve? This is the first time I have used a bleed valve since this is a new hose bib to the outside. Thanks in advance for anyone that can help me.
napostol is offline   Reply With Quote
Old 11-15-2008, 03:57 PM   #2
Custom Cabinet Maker
make sure you leave the outside valve OPEN, then with water off when u open bleed it should drain
skymaster is offline   Reply With Quote
Old 11-15-2008, 04:03 PM   #3
BUILDER / REMODELING CONT
buletbob's Avatar
Yes open the outside hose cock then like above said it will drain as long as the pipe is pitched towards the outside. BOB
Old 11-15-2008, 04:29 PM   #4
Went outside, opened the hose spigot and got downstairs to see the water shooting out of the bleed valve. Worked like a charm. Thanks for your help. A little water on the basement floor is easier to deal with than a broken pipe, and cheaper too.
Old 11-15-2008, 04:36 PM   #5
buletbob's Avatar
It would appear to what your saying is that the pipe is back pitched. I have my plumber pitch the pipes towards the outside from the shut off. this way when you shut the shut off , and open the outside hose cock it will drain to the outside. BOB.
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
garden hose water spillage questions mcvane Landscaping & Lawn Care 10 07-29-2007 12:27 AM
