Blanking Off Toilet Flange - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-28-2008, 12:14 PM   #1
Power Gen/RS Engineer
Rewards Points: 566
Blanking off toilet flange
Hi all-
I have a toilet in my basement that I want to remove. Do they make some sort of blanking plate that can be attached to the toilet flange to effectively cap it off?
Thanks!
Jimmy
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 04-29-2008, 07:38 PM   #2
Two ways I can think of. Use a test plug which has a wing nut on top that expands a rubber gasket inside the pipe when tightened. I use these when remodeling. Or go to a plumbing supply(forget the big boxes on this one) and get a blind flange and gasket for whichever size pipe you have and then fasten with closely cut closet bolts.
white29 is offline   Reply With Quote
Old 04-29-2008, 11:28 PM   #3
Registered User
Termite's Avatar
If you'll have access to it, I think the test plug is a great idea.
If you won't be able to get at it, I'd suggest breaking out a little bit of your slab and actually capping the pipe permanently.
Old 04-30-2008, 01:41 PM   #4
Since the pipe from the toilet will not have a trap, I would go with the test plug to guarantee no sewer gases are leaking into the room. You could then make a cover out of the material of your choice to attach to the flange with cut-off closet bolts.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 05-21-2008, 10:03 PM   #5
How to permanently cap it off?
How would one permanently cap it off? such that the flange is below floor grade. I would be doing this in a basement. Flange is in a slab. I relocated my basement bathroom and would like to permanently cap the old toilet flange such that I can tile over it. Thank you,
Earl
Earl43 is offline   Reply With Quote
Old 05-22-2008, 07:35 AM   #6
If I'm understanding you correctly I believe it could just be concreted flush with the subfloor.
Old 05-22-2008, 10:23 AM   #7
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Where I come from, a test cap or plug is not an approved fitting.
To do it right, you have to get at the pipe below the concrete, and glue on a 3" or 4" cap, whatever size pipe you've got.
Journeyman Plumber
Old 05-22-2008, 11:10 AM   #8
Earl. You need to seal the pipe to prevent sewer gases from coming through it. I have stuffed a rag tightly into the pipe and then used concrete to seal it off and smooth the surface. I would advise tying a wire around the rag and bring it up so the concrete will grab it. This prevents the rag from coming loose and going into other drainlines.
Old 05-22-2008, 06:49 PM   #9
thanks!
I appreciate your help!
Earl
Toilet closet flange kensington Plumbing 5 04-27-2008 09:19 AM
Toilet Flange and Flooring brneilly Remodeling 4 04-20-2008 12:37 PM
Toilet flange floor advice Hobb3s Plumbing 6 04-15-2008 10:41 AM
Rusted toilet flange on PVC pipe wyoming777 Plumbing 15 11-09-2007 10:53 PM
Toilet Flange txbostont Plumbing 5 10-31-2007 12:01 PM
