Old 11-24-2012, 06:00 PM   #16
call me E
TheEplumber's Avatar
Black water backup after roto-rooter cleared drain
Is there a toilet near the tub that is backed up? If there is, why isn't it as full as the tub?
Also, why can't RR pull a toilet and cable through the flange? It will be 3" pipe at minimum.
You either have a very unique system or an RR tech that is not seeing something except your wallet.
The Following User Says Thank You to TheEplumber For This Useful Post:
ben's plumbing (11-24-2012)
Old 11-24-2012, 09:37 PM   #17
if the main line was clogged ..all fixtures inside house would be affected.if other fixtures are working fine ..ITS NOT MAIN LINE...as mentioned the branch has to be clogged, they make a small snake with 1"cutter head capable of opening 3" line..what a pile of crap tell them to give you your money back and CALL SOMEONE ELSE.....sorry ...ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
imayearin (11-24-2012)
Old 11-24-2012, 10:36 PM   #18
Here is another update, this whole situation at this point is laughable. They came back today and power snaked through a cleanout we found by the septic. Of course, nothing happened. I swear I know more about plumbing then these guys...
The tech said he will be calling back on Monday to let us know of they will be bringing in their jetting machine to try next. At that point it will be one week. I think we are just going to call another plumber.
I had paid them a check before we discovered the backup, but we immediately stopped payment and they are not going to see a dime from me. I have a legal plan at work so will just have a lawyer send them a letter, maybe with the septic pumping bill and plumber's bill.
tukka is offline   Reply With Quote
Old 11-24-2012, 10:43 PM   #19
you gave yourself the best advice yet....do just that..ben sr
oh'mike (11-25-2012)
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Two plumbing questions: Water heater drain and expansion tank. TexasPenguin Plumbing 10 10-30-2012 02:35 PM
Very Low Hot Water Pressure. PAS1970 General Discussion 2 02-25-2009 04:01 PM
Water softener & Iron filter drain DSKUP Plumbing 3 02-17-2009 11:14 AM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 11:52 PM
