#1 |
Black vs Galvinized down by the ocean
local plumber in conversation said galvinized is the way to go with less or no rotting out over the years compared to black pipe from the meter to the kitchen and boiler room..need a pro plumber's take on it...thanks
#2 |
Master General ReEngineer
Ayuh,.... waterlines,..?? plastic never rusts....
#3 |
Must be a really old plumber is he's still using steel pipe of any kind if it's water lines your talking about.
CPVC, Pex, or copper are the norms for the past 20 years or so. Steel pipe rusts out from the inside out and at some point will leak, burst, or close up on the inside and reduce flow. |
#4 |
call me E
Are you talking gas or water...
When posting in forums, letting us know your location will help others give better feedback/advice/solutions to your questions |
#5 |
natural gas ....while i have you here would you know the standing pressure test in PSI and time to verify on a main gas header thru a home meter to shut offs only not up to loads...thanks
#6 | |
Black vs Galvinized down by the oceanQuote:
#7 |
No one said you couldnt ask questions. Too bad you needed to cop an attitude here and name call like a child. I could have really helped you out. Oh well, good luck with your little project.
| The Following User Says Thank You to hvac benny For This Useful Post: | rjniles (10-05-2012) |
#8 |
come on guys
#9 | |
#10 |
Black vs Galvinized down by the ocean |
#11 | |
| The Following User Says Thank You to hvac benny For This Useful Post: | ben's plumbing (10-05-2012) |
#12 |
JOATMON
Hey....looks like a good time to give our new mod Jim some work.....
Common Sense is like Deodorant. Those that need it the most don't use it. My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| The Following User Says Thank You to ddawg16 For This Useful Post: | BigJim (10-05-2012) |
#13 | |
call me E
| Display Modes | |
| Double switch wiring | rockclimber | Electrical | 18 | 03-18-2012 11:13 PM |
| Newbie from Beverly MA and BLACK trim! | Rellie25 | Introductions | 3 | 11-30-2009 10:24 AM |
| Please Help! 3 way switches controling 2 light fxtures. | HelloMotto | Electrical | 50 | 09-01-2009 09:20 PM |
| Black Iron Exposed? | jamiedolan | Plumbing | 0 | 08-14-2009 11:16 AM |
| hooking up dryer....bronx ny code | SURFBUG | Appliances | 6 | 10-14-2008 10:41 PM |
