Black Stuff On Pipes Before Slab Pour? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-01-2013, 10:38 AM   #1
Black stuff on pipes before slab pour?
What is that black mastic stuff that is put on the drain pipes before the slab is poured. Is there a brand name, can I get it at Home Depot? The plumber said the concrete guys will put it on, but I thought the plumber would do that. May just do it myself if concrete guy doesn't do it.
Howard
HowardBrown is offline   Reply With Quote
Old 08-01-2013, 11:23 AM   #2
Rewards Points: 13,256
What are the pipes made of?
I've never seen anyone coat drain lines with anything.
Old 08-01-2013, 11:38 AM   #3
Pipes are PVC. My understanding is that it keeps the conrete from sticking to the pipes. I've seen it done alot around here. The stub ups are all coated with it from the ground up past where the concrete is poured.
Old 08-01-2013, 11:45 AM   #4
Guess that would work.
Ours are wrapped in nylon rope that gets pulled out then it's cured.
Pier on slab cer2012 Building & Construction 0 04-16-2012 09:52 PM
I want to pour a small slab... Any pointers? Alan Building & Construction 2 04-17-2010 06:46 PM
Help with black fuzzy stuff freaknyea General DIY Discussions 14 12-09-2008 06:09 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
reuse black pipes nikwah Plumbing 5 10-12-2008 10:38 PM
