Black Residue From Pipes? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-14-2012, 11:36 AM   #1
Rewards Points: 208
Black Residue from Pipes?
my house was built in the 1950s and uses well water. after cleaning for an hour, i noticed a black residue around my finger nails. could this be from the pipes? i think the pipes are copper.
the water that comes out of the tap is clear and i see no sediment build up after letting the water sit in a bowl.
Scully is offline   Reply With Quote
Old 04-14-2012, 11:38 AM   #2
Rewards Points: 13,458
May want to have your water tested.
Old 04-14-2012, 11:40 AM   #3
Rewards Points: 208
i had the well water tested back in nov. and it came back fine.
Old 04-14-2012, 12:10 PM   #4
DO you have an activated charcoal water filter in that line?
Old 04-14-2012, 03:44 PM   #5
Rewards Points: 208
i don't think i do. could the black residue be from the copper pipes?
Old 04-15-2012, 10:04 AM   #6
Rewards Points: 208
i am seeing very tiny black flecks in my water. where is it coming from???
Old 04-15-2012, 09:15 PM   #7
Like JoeC suggested, and it sounds to me, that you may have a charcoal filter somewhere. Do you have a reverse osmosis system in your house? How do you treat your well water?
VIPlumber is offline   Reply With Quote
Old 04-15-2012, 09:23 PM   #8
Rewards Points: 208
i just have a water softener. i don't have a charcoal filter as far as i can see. should i call a plumber or a well guy?
Uploaded with ImageShack.us
Old 04-15-2012, 10:26 PM   #9
I couldn't see a filter housing of any kind either, so maybe the black flecks/residue is coming from your well. Could be some organic or inorganic substance down in there that's coming up through to your house's pipes. What kind of water tests did you have done on the well? I'm surprised that there was no suggestion of installing a whole house filter on the system. It usually accompanies a softener, is pretty inexpensive, and is excellent insurance in filtering out unwanted debris.
Old 04-15-2012, 10:34 PM   #10
Homerepairguy's Avatar
Rewards Points: 998
Originally Posted by Scully View Post
I see a valve with a hose bib connection at the left end of the piping coming out of the blue tank. Try getting some water from there and see if the black flecks are in the water. If yes, then you just eliminated all of the plumbing after that point.
HRG
Homerepairguy is offline   Reply With Quote
Old 04-15-2012, 10:49 PM   #11
Rewards Points: 208
the well water test was pretty extensive: lead, nitrate, arsenic, ecoli. could it be the rubber gaskets in the hot water plumbing?
should i call a well guy or a plumber?
Old 04-15-2012, 11:01 PM   #12
If it was rubber gaskets somewhere in the system, which maintain a seal against water leakage, then you'd have water leaks. Try HRG's suggestion to see if you can't eliminate the house plumbing first.
Old 04-17-2012, 12:08 AM   #13
Rewards Points: 208
i have a feeling that i'm dealing with clear water iron. will an iron curtain filter do the trick?
i've been thinking about ditching the well and pipe in chlorinated city water, but it could get very costly.
Old 04-17-2012, 12:28 AM   #14
I think I see the problum.
You have steel pipes coming off of your pressure tank connected up to copper pipes.
Get rid of the steel pipes and replace with bronze or copper and the problum should go away.
With steel pipes it's only a matter of time before they leak or plug up inside.
When you have copper and steel in contact you get electrolisis which will corrode the pipes far faster.
Using 14/3 with black and red hot = code? hellothere123 Electrical 7 09-20-2010 09:20 AM
No Cold Water at all - both cold and hot pipes are burning to the touch bluecifer Plumbing 12 01-19-2009 10:29 AM
Frozen Pipes? Plugged pipes? brokenhammer Plumbing 7 01-15-2009 11:10 PM
New Natural Gas pipes being installed frplymstr Plumbing 12 01-05-2009 01:18 PM
reuse black pipes nikwah Plumbing 5 10-12-2008 09:38 PM
