Black Plastic Pipe For Natural Gas? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-08-2012, 03:42 PM   #1
Black Plastic Pipe for Natural Gas?
Can I use Black Plastic Pipe to run Natural Gas to a patio heater?
Would soft copper be better?
I had a Natural Gas BBQ pit that the gas company installed about 20 years ago. They used 3/8" black plastic pipe from the meter to the pit all under ground. I have not used it for a long time and want to install a gas heater but would like to use 1/2" instead.
Please advise.
diy-novice is offline   Reply With Quote
Old 09-08-2012, 05:08 PM   #2
DIY staff
Rewards Points: 7,174
I moved this to plumbing for you---A licensed plumber wil answer you---your location is needed because codes vary on exterior gas lines---
Black plastic? NO---
DangerMouse (09-08-2012)
Old 09-08-2012, 05:17 PM   #3
Plastic pipe can only be used underground. Yellow polyethylene is what is used, although there is some orange PE in the ground here from years ago. Whatever you do use, make sure it is approved for gas in your area.
hvac benny is offline   Reply With Quote
Old 09-08-2012, 07:08 PM   #4
Rewards Points: 582
Please advise.
NO....to answer your direct question....but as was mentioned local gas company should be notified as to there requirements for your install.....most small heaters can run on small copper tubing from a properly sized supply line..and its safer....
Old 09-09-2012, 02:20 PM   #5
Thanks for the reply. I live in the Houston, Tx. area.
So I can only use Yellow Plastic Pipe? Or would soft copper be better?
It will all be underground.
Old 09-09-2012, 07:49 PM   #6
Check with your local building inspector to determine what type of pipe and connection is approved for use in your situation. Also, many local authorities required a licensed professional to do all gas piping work and if your area requires a licensed professional and you do it yourself you put your insurance coverage at risk if anything happens down the road.
Bob999 is offline   Reply With Quote
Old 09-10-2012, 07:42 PM   #7
I am aware of the the insurance issues. Just tring to plan on how
much this project is going to cost. I will check with the local authorities on what is required.
Thanks again for the reply.
Black Corrugated Pipe -or- SCH 40 PVC for driveway trench drain stevekem Landscaping & Lawn Care 3 08-26-2012 10:08 PM
Black Pipe to Pex dvid Plumbing 1 10-18-2011 05:14 PM
black pipe for hydronic radiators amakarevic Plumbing 2 09-24-2011 04:03 AM
What’s the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 01:05 AM
Splicing ABS Black Vent Pipe Garfield Plumbing 1 12-07-2009 02:53 PM
