Black Pipe Union (1-1/2") Leaking - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-27-2010, 07:11 PM   #1
Black Pipe Union (1-1/2") leaking
I'm running 1-1/2" natural gas line (black pipe) for a whole house generator. I can't seem to install a union that doesn't leak. I'm on my 3rd union and they all leak in the same place.....the compression part. No problem with the ends of the union that are threaded onto the mating pipes, but it appears I can't tighten the compression part enough to create a leak proof seal. What am I doing wrong. First union was purchased from the Home Depot (could be lower quality). Second from Loews (probably same quality). Third was purchased from a plumbing supply (Aarons). They all leak exactly the same. Any ideas or suggestions?
Thanks in advance!
g-dub is offline   Reply With Quote
Old 06-27-2010, 07:37 PM   #2
Water Treatment
Rewards Points: 848
Thanks in advance!
You are using some of the liquid pipe dope on the threads, use a little on either the male or female or where the two parts come together.
A plumber tough me that little trick years ago on unions that where not sealing right and having to use mega to maybe stop the leaking..
Akpsdvan is offline   Reply With Quote
Old 06-27-2010, 08:21 PM   #3
I used Blue Block pipe dope on the ends of the union that connect to the pipe. No leaks there. I did NOT use any pipe dope on the threaded part the pulls the compression pieces together, figuring the seal was made by compression.
Old 06-27-2010, 09:39 PM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
X2 on the pipe dope idea.
If your piping isn't aligned 100% you're going to have issues. Put a little dope on the mating surfaces and tighten it down as tight as you can get it without cracking it.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
plummen (06-28-2010)
Black pipe unions for gas? bansheex HVAC 6 06-23-2010 10:29 AM
Tee-ing into gas (black) pipe WaldenL Plumbing 3 01-13-2009 10:46 AM
Water heater hot outlet union leaking dog193 Plumbing 4 01-10-2008 10:07 AM
Repairing black poly pipe MelAuston Plumbing 4 10-31-2007 09:54 PM
Leaking Pipe STEPBK2 Plumbing 1 12-06-2004 01:57 PM
