Black Pipe For A Stove - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-21-2012, 10:46 AM   #1
black pipe for a stove
I'm moving my stove to another wall. Can black pipe be installed in a wall or does it have to run through the ceiling? If it can run through a wall, at what height should it be installed?
Retired Mary is offline   Reply With Quote
Old 01-21-2012, 10:50 AM   #2
Rewards Points: 13,228
By stove do you mean cooking stove?
Is this a gas pipe? If so yes it can be run through a wall but it's not a DIY, any gas lines should only be work on by a licenced plumber with an added gas licence or the gas company.
Old 01-21-2012, 11:49 AM   #3
MarginallyQualified
Rewards Points: 2,464
I think you may mean a thimble for the flue pipe...
Old 01-21-2012, 11:55 AM   #4
If that's the case then there's kinds of clearace issues, and no black single walled pipe should not be used.
Leaking drain pipe under kitchen sink dethun Plumbing 22 03-13-2016 06:53 AM
cold room to warm room pipe run herennow HVAC 0 01-16-2011 08:37 PM
insulating black pipe for gas hot water furnace anwhite80 HVAC 0 12-15-2010 11:11 AM
Poly Gasline to replace Black Pipe? GabeD Plumbing 9 08-29-2010 12:47 PM
Wood Burning Stove Pipe Question jh756 HVAC 1 08-20-2010 03:19 PM
