Black Pipe To Pex - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-17-2011, 07:09 PM   #1
Black Pipe to Pex
I have to replace a section of black pipe that is used for my hot water radiator heating system. Can I connect pex pipe in that section? Is there a fitting for going from black pipe to pex?
dvid is offline   Reply With Quote
Old 10-18-2011, 05:14 PM   #2
Yes, you can use PEX tubing, but make sure it's the PEX specifically made for heating applications (it has an oxygen barrier that inhibits the introduction of oxygen into the system which can accelerate corrosion). There are brass PEX x IPS (male or female) adaptors that can be threaded onto/into black pipe or black malleable fittings.
The pipe could also be easily replaced with copper tubing.
Ishmael is offline   Reply With Quote
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 09:16 PM
poly gas pipe to black pipe connection hamsam Plumbing 2 05-03-2009 09:47 PM
Anyone use 2" black poly pipe? hawgdawg50 Plumbing 6 10-08-2008 11:22 AM
Identifying size of Black Iron Pipe jamiedolan Plumbing 2 10-06-2008 12:39 AM
Rust Spot on Water Pipe (Cast Iron or Black Iron maybe?) markmaclean80 Plumbing 6 08-22-2007 08:20 PM
