Black Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-11-2010, 09:52 PM   #1
Black Pipe
I installed a gas outlet for a range last year and now need to move it over a few inches to accomodate a new range. Can I tighten an elbow 45 degrees without risking leakage, or should I just remove it and re-paste the joint.?
squarehead is offline   Reply With Quote
Old 08-12-2010, 12:15 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 550
Either tighten it more or redo the joint. Either way, you need to soap test it for leaks before putting it back into service!
Old 08-12-2010, 08:41 AM   #3
As long as you are not loosening the joint, there should be no problem. As stated, test the joint before use.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 08-14-2010, 07:08 AM   #4
Rewards Points: 1,216
Shut off main @sourse
Tighten turn ell
Shut off line at range
Turn on main
Soap joint that you tightened, leak check
No leaks, turn off main proceed to complete hookup, turn main back on and leak check all joints
No leaks put in service.
COLDIRON is offline   Reply With Quote
Gas Pipe General Questions jamiedolan Plumbing 10 12-06-2012 10:46 AM
poly gas pipe to black pipe connection hamsam Plumbing 2 05-03-2009 09:47 PM
Anyone use 2" black poly pipe? hawgdawg50 Plumbing 6 10-08-2008 11:22 AM
Identifying size of Black Iron Pipe jamiedolan Plumbing 2 10-06-2008 12:39 AM
Rust Spot on Water Pipe (Cast Iron or Black Iron maybe?) markmaclean80 Plumbing 6 08-22-2007 08:20 PM
