-   -   Black Pipe (http://www.diychatroom.com/f7/black-pipe-78538/)
squarehead 08-11-2010 09:52 PM
Black Pipe
I installed a gas outlet for a range last year and now need to move it over a few inches to accomodate a new range. Can I tighten an elbow 45 degrees without risking leakage, or should I just remove it and re-paste the joint.?
TheEplumber 08-12-2010 12:15 AM
199 Attachment(s)
Either tighten it more or redo the joint. Either way, you need to soap test it for leaks before putting it back into service!
majakdragon 08-12-2010 08:41 AM
As long as you are not loosening the joint, there should be no problem. As stated, test the joint before use.
COLDIRON 08-14-2010 07:08 AM
Shut off main @sourse
Tighten turn ell
Shut off line at range
Turn on main
Soap joint that you tightened, leak check
No leaks, turn off main proceed to complete hookup, turn main back on and leak check all joints
No leaks put in service.
