Black Material In Water Filter - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-07-2012, 02:00 PM   #1
Hello
My wife and I recently bought an old farm house. The house came with a rather elaborate water filtration system. From the main well, the water enters a tank for iron removal then goes to a water softener, and then through a filtration system before heading into the house. At the point between the main well line and the iron filtration system, there is a filter which hangs off the water pipe and filters the water just before it enters the iron filtration system. The filter is just a tubular paper filter, which fits into an 8in plastic cup which screws on to the main water line. The cup is clear plastic and it is see through, however as the filter gets dirty, the water blackens and I am no longer able to see through the filter cup anymore.
I was told to make sure that I change the filter approximately once every 2 to 3 months. While I fully understand the job of a filter, there is a black material which the filter seems to be covered with when its time to change it. In addition, the inner side of the filter cup becomes completely black with this material. I spoke with the guy who works in the well industry, and he called it hydrogen - "something" and defined it as a combination of all of the minerals in the water. I ask him if this material was toxic in anyway and he said no.
I was wondering if someone could better define the hydrogen term that he used, and verify the information.
Sartrean is offline   Reply With Quote
Old 03-07-2012, 02:14 PM   #2
Experienced
Jackofall1's Avatar
You could read this
http://ohioline.osu.edu/aex-fact/0319.html
Mark
Old 03-08-2012, 12:00 PM   #3
I believe that the previous poster is on the right track as Hydrogen Sulfide, when oxidized, falls out of water and turns black. I believe manganese does this as well. You may have a high amount of disolved oxygen in your water which would aid the process of oxidation. The iron filter was probably put in to help remove the HS or manganese. I would think that the iron filter would handle removing this from the water, but it could be the case that the filter is installed to help lower the burden of the iron filter and extend its life.
guisertj81 is offline   Reply With Quote
Old 03-08-2012, 02:41 PM   #4
If your water has hydrogen sulfide, a gas, the water will smell of rotten eggs before treatment/removal. Manganese has no odor. So if your water has the rotten eggs smell the black substance may be precipitated hydrogen sulfide or manganese, or both. If no odor it is probably a preciptated form of manganese. Both oxygen and chlorine will react with hydrogen sulfide and manganese and create a form which will preciptate out of the water or which can be mechanically filtered.
Bob999 is offline   Reply With Quote
Old 03-09-2012, 05:31 PM   #5
Thank you all for helping put our minds at ease. It does not appear toxic as much as a nuisance. Thanks again
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
Upgrading water supply plumbing...where to locate filter? Jim S. Plumbing 3 02-06-2009 11:13 AM
