Is Black 4" PVC Still In Use? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-27-2008, 04:52 PM   #1
Is Black 4" PVC still in use?
I have several lengths of Black 4" PVC.
1. Is this still used for waste drainage?
2. Is it a different kind of PVC from schedule 40?
3. Can the two be used together? Can schedule 40 PVC connectors be used on the black PVC?
Randell Tarin is offline   Reply With Quote
Old 01-27-2008, 04:57 PM   #2
Are you sure it's PVC and not ABS?
jerryh3 is offline   Reply With Quote
Old 01-27-2008, 05:17 PM   #3
I checked. Yes it is ABS. Do you have to use ABS fittings or can it be used with PVC?
Old 01-27-2008, 07:24 PM   #4
Long-Time DIYer
Mike Swearingen's Avatar
ABS has to have ABS "glue" and PVC has to have PVC cleaner and "glue".
To connect the two requires another special "glue" designed for the purpose. Check the container to get the right kind, or it won't hold.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 01-28-2008, 05:15 AM   #5
Union HVAC Tech.
The combo glue isn't code approved in many places, most guys would ise a male-female threaded connection in that case.
bigMikeB is offline   Reply With Quote
Old 01-28-2008, 05:28 AM   #6
Send a message via AIM to Marlin
A banded no hub clamp should be fine as well so long as it isn't being buried.
Marlin is offline   Reply With Quote
Old 01-28-2008, 05:58 AM   #7
you can bury a code approved shielded band. thats the easy est way to make a connection with different types of pipes. just get the proper band
ranman469 is offline   Reply With Quote
Old 01-28-2008, 06:02 AM   #8
Union HVAC Tech.
It's just cheaper and easier to use the proper coupling and leave no-hub and Ferncos for cast iron or clay where there is no other choice.
Old 01-28-2008, 11:37 PM   #9
This is going in a new install. I have a couple of guest cottages on my property and there getting a new septic sytem.
Is the band you guys are talking about the rubber boot with the metal band wrapping around it?
Old 01-29-2008, 05:42 AM   #10
Long-Time DIYer
Randell,
For burial, the neoprene rubber sleeve with two stainless steel bands (aka name brand Fernco coupling) are usually code-approved.
For connections that will NOT be buried in the ground, the no-hub (aka brand name Mission coupling) are usually code-approved. These are the couplings with the stainless steel sleeve over a neoprene rubber sleeve.
Mike
Old 01-29-2008, 05:46 AM   #11
here is one. they tighten to 60in lbs
http://www.acehardwareoutlet.com/(ua...aspx?SKU=44924
Old 01-29-2008, 09:22 AM   #12
Thanks Guys. I have seen these before...just didn't know what they were called.
Old 02-01-2008, 02:27 AM   #13
Master Plumber
Rewards Points: 150
In Texas, ABS is not code approved, you need to use PVC. What type of coupling you use (fernco or mission band) depends on the municipality that will inspect it, so you need to check with the inspection dept. The fernco's are going to need a shear band around it which essentially makes it a extra heavy mission band. But you need to chuck out that ABS that has been laying around where ever you got it and use PVC so you don't need those hose clamp couplings. The PVC needs to be connected with purple primer and PVC glue. If you have ABS or Cast Iron coming out from under the cottage then you will need to use a transition coupling to the new PVC.
jpplumber is offline   Reply With Quote
New black bathroom floor - NOW WHAT? mizi Interior Decorating 11 01-11-2008 03:29 PM
Repairing black poly pipe MelAuston Plumbing 4 10-31-2007 08:54 PM
Install hardwood over black mastic? SuperDoug Flooring 2 10-28-2007 12:52 PM
Is there any black PVC ? Melanie337 Plumbing 2 09-15-2007 12:03 AM
Black wood putty JOHNL Carpentry 2 04-27-2007 10:35 AM
