Old 07-07-2012, 04:30 PM   #1
Bii 0865-120
I opened it and started to flow water from 4 holes in the stem ? If I use it the water flow cont.
ricardo camus is offline   Reply With Quote
Old 07-07-2012, 05:14 PM   #2
the Musigician
DangerMouse's Avatar
Bii 0865-120
Is this a question? This is a forum, not google. We are real people here.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 07-07-2012, 05:49 PM   #3
Bii 0865-120
Let see if I can translate:
The OP has a model Bii 0865-120 frost free faucet that leaks through 4 holes when open.
This thread talks about the same faucet frost free faucet - cannot turn on
If the faucet is leaking out the handle there is a washer you can replace. If there are 4 holes in the long pipe from the handle to the valve, you will have to replace the faucet.
Interestingly, the only matches for Bii 0865-120 in Bing were from this forum.
goosebarry is offline   Reply With Quote
