| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
The Beginning of Installing a Ball Valve
by Expert Village
Hi! This is John on behalf of Expert Village. In this video clip, I will show you step 1 for installing a ball valve. I am going to be installing a ball valve on this pipe. This pipe is a hot water pipe, and I know that because when I trace it back, it... Read More »
How to Find a Broken Toilet Part
by eHow.com
We've all heard the frantic request from the bathroom to bring the toilet plunger before the toilet runs over. All of us will cope with a toilet malfunction at one time or another. Some repairs are best left to the experts, but many fixes are simple once... Read More »
Shut Off Water for Toilet Repair
by Expert Village
Hi this is Jon on behalf of Expert Village in this video clip I will be taking you through the procedure for shutting off our water supply. If you take a look behind our toilet you would see that there is a shut off valve to shut this off you want to... Read More »
Hot Water Lines in Bathroom Installation
by Expert Village
We are going to talk a little bit about how we are going to get water to our shower, our toilet, our new washing machine, and our sink. What I had to do was I had to find a place where I could pull cold water and also pull hot water and being that these... Read More »
Identifying Problem With a Toilet
by Expert Village
Now, to check to see if this toilet has a leak in it, what you can do is you can take, and put a little bit of food coloring into the tank. If there is a leak in this toilet, the water food coloring will go through the tank, and end up in the bowl. So... Read More »
