Old 10-05-2009, 07:17 PM   #1
Angry Big Mistake with a basement shower drain
I made the mistake of cementing(PVC) in a shower drain base without noticing that the drain I purchased is for a tiled shower instead of the fiberglass one piece unit I have. If I leave it the way it is, the drain sticks up about 1/8" above the base of the shower. So, my options are: 1. Live with it (with some trickery involving some channels grooved into the sides, it drains well). or 2. ????????
I have this thing stuck in some 3" PVC in the floor. Could I break this thing out of there and somehow fit 2" pvc inside the 3" PVC? (seems like there are a ton of drains designes to fit around the 2" stuff). Would I have to break up some concrete to put something around it? Could I do that with a chisel? (If you can't tell, I'm a little frustrated by this stupid mistake and probably would be more inclined to live with this if it wasn't a constant reminder of my stupidity every time my foot brushed across that drain).
lindq175 is offline   Reply With Quote
Old 10-06-2009, 12:33 AM   #2
Would you consider "raising the floor"?
That is, putting down a a sheet of vinyl flooring or something in the shower stall to match the level of the drain collar.
You would have to either seal it down hermetically using caulking, or leave it loose so it could be lifted off and sanitized on both sides periodically.
Bait gone and the mouse trap has not snapped? Maybe ants got there first.
Old 10-06-2009, 07:59 AM   #3
would that look good with a fiberclass one-piece? I've never heard of that....is it done often?
I've been thinking about this....do they make a fitting to fit 2" pvc inside of 3" pvc? That way I could cut out the current piece, cut out the pvc about 2" below the cement, and fit some 2" PVC inside. Thoughts?
Old 10-06-2009, 02:58 PM   #4
so. I've figured out what I'm going to do. (for anyone that cares). I'm going to cut out the misplaced drain base. Stick some 2" pvc inside the 3" pvc with some some construction epoxy filling in the gap around the 2". Then I'm going to mount a standard drain over the 2" pvc. Sounds like a plan to me. Thoughts?
Old 10-06-2009, 04:11 PM   #5
any chance of just trimming off the extra 1/8" and putting the drain cover back on? Or, if the shower base isn't installed fully to the floor, could you use the vinyl flooring under it to raise it up (or shims or leveling concrete or...*) This would give you the extra height, without doing anything inside the shower base.
* Disclaimer: Not sure on what things would work well under it, but just gave some examples, which may or may not work.
jimmyfloyd is offline   Reply With Quote
Tags
basement bathroom, drain, shower
More On This Topic
Alright, lets talk about unknowledgeable for a minute. What you never want to do is make assumptions about what unknowledgeable means. Does that mean that your audience is stupid? Absolutely not. What it means is they don't know about your topic. Does... Read More »
Hi this is Fernando we are here with Expert Village and now we are going over before you actually start installing a sprinkler heads. We have laid down our pvc piping, we have connected our pvc pipes, we have actually done our joining corners and we seal... Read More »
Hi, on behalf of Expert Village, this is Chris Murphy at the Broadway Comedy Club here in New York City. And today I'm going to talk to you about becoming a stand-up comic. Ok, hecklers. I get this question asked to me probably more than anything else... Read More »
We have a second bathtub that we're going to be treating a little bit differently so we have two that we're going to be working with. The drainage system that we're going to use in this one is going to be from a PVC pipe. This is a thin walled what is... Read More »
A T-shirt rack is a drying rack that allows T-shirts to dry without wrinkling and without stretching out the collar. This T-shirt rack is made from PVC pipe so it never rusts and is lightweight. Assemble the drying rack in less than one hour and be on... Read More »
sewer backed up in basement floor drain and shower kristina1961 Plumbing 11 04-13-2009 02:19 AM
New tiled shower won't drain; mortar in drain. catitudes Plumbing 5 03-29-2009 03:08 PM
Basement Shower Drain Problem! cleveland1980 Plumbing 14 03-14-2009 06:02 PM
AAV or Studor Vent Needed for this Tub and Shower Drain? BillyDIY Plumbing 1 12-17-2008 01:11 AM
Different type of shower drain? canadaclub Plumbing 4 02-14-2008 07:31 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
