Old 12-14-2012, 10:29 PM   #1
Bidot advice
Not to sure if I will get much help on this subject. Can any one recommend a bidot seat or such attachment that will go on my toilet? I had a toto one a while back that I bought new for 350 bucks through a friend. I check today and they are around 1200 dollars. I can spend up to $300 dollars. Have been looking at some of the under $100 dollar ones and not sure if they are safe as far as leaks go. No room for a full bidot.
paintdrying is offline   Reply With Quote
Old 12-14-2012, 11:17 PM   #2
Bidot advice
Save yourself a buck and just put another shutoff within handsreach of the setter. Run 1/4" flex copper up and under the seat. Leave it long, then cut off so that about 1/2" protrudes past the seat.
Now take a crescent wrench or something that won't mar too bad, and give it a slight aim upwards.
Test.
Adjust as necessary.
I've installed a lot of these with a seat valve shut-off and recently installed one with a 1/4 turn ball valve type shut off. It delivers water in a hurry.
cleveman is offline   Reply With Quote
Old 12-15-2012, 08:24 AM   #3
Bidot advice
That is really good advice. That is going to be the safest cheapest way. Thanks alot.
Advice is not always correct! Docwhitley Plumbing 9 02-14-2011 10:12 PM
Chain link fence install advice ponch37300 Landscaping & Lawn Care 1 11-10-2010 07:08 PM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
looking for Serious advice and Help on Insulation bfan781 Building & Construction 6 05-19-2010 12:02 PM
Electrical Advice Caution!!! Mike Swearingen Electrical 12 03-05-2008 12:51 PM
