Old 02-20-2008, 03:23 AM   #16
Master Plumber
Which is better? WAX or Non-Wax toilet ring?
If by "high tech" you mean foam ring...they have been used on urinals for years and will work just as well as long as you have the right thickness, it is the same material as on the toilet tank to bowl gasket. I've also pulled some old toilets that must of had a whole tub of plumbers putty squashed underneath for the seal...it worked. Having said that.... I prefer to use the wax ring with no plastic cone.
jpplumber is offline   Reply With Quote
Advice on commercial toilet install SoCalSwami Plumbing 9 05-15-2008 04:43 PM
New Toilet Does Not Flush klugej Plumbing 3 04-30-2007 11:51 AM
Leaking pipe under toilet aprildawn Plumbing 4 01-21-2007 05:32 PM
Replacing a Toilet dandgluna Plumbing 8 07-10-2006 11:09 PM
Toilet; Cistern to Toilet pipe ( Complete Novice) broke1973 Plumbing 1 07-15-2005 09:34 AM
