Better Supply For Humidifier? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-27-2012, 09:04 AM   #1
Stay-at-home GC
Better supply for Humidifier?
Any ideas for a better way to supply a whole house humidifier attached to the plenum of my furnace?
Currently I have a saddle tap (vampire tap) fitting into compression copper tube. Problem is the fitting is getting corroded and it's very difficult to gauge the amount of water feeding to the humidifier.
The overflow/waste tube to the condensate pump was black making it very tough to see how much water I was dumping down the drain. I've changed it out to clear.
I fought with it all winter, measuring it into 5 gallon buckets to see how much I was losing per hour but it would be much easier to solve if I could see how much I was supplying.
I was thinking of sealing off the saddle puncture. Running a new supply branch to near the humidifier then adding a valve either into a clear compression tube or ideally some kind of clear drip chamber like you see on a hospital IV.
Ideas?
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 04-27-2012, 09:10 AM   #2
Stay-at-home GC
True Union Metering Ball Valve? But I only see them in PVC which I could transition fitting to but still no clear view.....
Old 04-27-2012, 09:16 AM   #3
Rewards Points: 14,020
#1 Get rid of that saddle valve, replace it with a ball valve.
#2 Any I've seen use a float switch to control the water level, not count on a valve to control flow something like this switch.
http://www.filtersfast.com/P-Skuttle...0-0814-132.asp
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Distance between HVAC supply and return vents atlantatd HVAC 4 04-13-2011 08:30 PM
Need help fast please re hydronic boiler water supply and backflow DanDaMan HVAC 6 12-11-2010 02:26 PM
Supply valve to bath faucet doesn't stop water Kurt123 Plumbing 2 09-05-2010 09:48 PM
Extending Water Supply Box In Laundry Room hsl Building & Construction 0 11-18-2009 09:21 AM
