Old 01-05-2010, 11:47 PM   #1
Best and worst Water Heaters?
What brands of residential water heaters are better and which ones are not good? Thank you.
hundzu is offline   Reply With Quote
Old 01-05-2010, 11:52 PM   #2
I'd say avoid the tankless kinds, unless you have special circumstances.
pyper is offline   Reply With Quote
Old 01-06-2010, 09:45 PM   #3
Do something
D'Brie's Avatar
Bradford-White = tank
Rinnai = tankless
About the best you can get.
Whirlpool, G-E = CRAP for tank
Bosch = CRAP for tankless
D'Brie is offline   Reply With Quote
Old 01-07-2010, 12:29 PM   #4
i think there are only 2 or 3 u.s. heater manufactures.all they do is slap different stickers on them.you pay for the warranty.you pay for a 6yr.warranty,the manufacturer hopes it last 6yrs and 1 day and so on.the best thing to remember is that to keep the heater above 120 deg.F,ad a exp. tank sized for your heater and set to the incoming water pressure if you have a backflow preventer,pressure reducing or a water meter with dual check valve on the supply line to your house.thermal exp.tears up water heaters.
rudolph58 is offline   Reply With Quote
Old 01-07-2010, 12:31 PM   #5
forget-you don't a exp. tank on a tankless heater
Old 01-07-2010, 01:05 PM   #6
Maybe I'm just lucky, but mines about 10 years old now and works as well as it did on day 1.
Old 01-07-2010, 01:19 PM   #7
what brand is it?
Old 01-07-2010, 01:38 PM   #8
Rudolph,
Thank you very much. Scouring the internet led me to believe that Bradford White was better quality than all the others. you confirmed that. Can only get a Bradford White from a licensed plumber? No one sells them to the public?
Did you get much snow in central Illinois? I live in St. Charles, MO. We got 4-5 inches of snow and the temperature is dropping!
Neal
Old 01-07-2010, 01:48 PM   #9
about the same here.waiting for the wind and frigid cold
Old 01-07-2010, 02:22 PM   #10
I concur. I recently installed the ES 800 GWH (NG) model. Installed it myself without problems. Works great. It's so efficient I was able to vent it with PVC pipe.
gbwillner is offline   Reply With Quote
