Old 03-21-2008, 09:36 PM   #1
When is fishing season?
CowboyAndy's Avatar
Best way to trim a tub surround?
I need to trim a tub surround. It is just a basic thin cheapie surround. The reason it needs to be trimmed is because it is on a slant wall, and is about 3 in too tall.
What should I use to trim it?
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 03-21-2008, 09:42 PM   #2
Building and plumbing
USP45's Avatar
I have used the white PVC 2-1/4" trim from Lowes at times. Plastic so it will not rot.
USP45 is offline   Reply With Quote
Old 03-21-2008, 09:58 PM   #3
CowboyAndy's Avatar
Okay, maybe I phrased it wrong.
I need to cut it down. It is 3 in too tall.
MY HOUSE OWNS ME!
Old 03-21-2008, 10:11 PM   #4
USP45's Avatar
My bad, ok, use a very sharp new razor knife blade. Lay a straight edge across the line you want to cut and score it several times. I it is one of those flimsy thin Lowes specials this should work. Just make sure the surround is at room temp and not cold. If the pannels are not flat, but rather contoured, then I would try a grinder with one of those real thin metal cutting blades and go ever so slow.
Old 03-21-2008, 10:55 PM   #5
CowboyAndy's Avatar
Ya, its flat... and pretty thin. Although, the corners have shelves, and are somewhat rounded.
What about using a jig saw with a very fine blade, like one similar the ones for laminate countertop?
MY HOUSE OWNS ME!
Old 03-22-2008, 12:16 AM   #6
Journeyman Plumber
Ron The Plumber's Avatar
If it's anything like formica, then apply tape along your cut line. I have not done this myself, I myself wold use a razor blade over a jigsaw.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 03-22-2008, 10:50 AM   #7
CowboyAndy's Avatar
okay. i'll try it with the razor knife.
thanks for the help!
MY HOUSE OWNS ME!
Sidelight - Cannot find vinyl trim lrichards Building & Construction 2 08-28-2008 05:42 PM
Which paint to use? Painting wood trim white Proulx06 Painting 11 04-09-2008 09:18 PM
baseboard trim gaps on stairs beppygirl General Discussion 8 02-24-2008 02:31 PM
attaching baseboard trim DIY4EVER Carpentry 11 11-28-2007 01:31 PM
Help for painting trim and doors: We need your advice! AaronandSteph Painting 2 01-01-2007 11:16 PM
