Best way to trim a tub surround?
I need to trim a tub surround. It is just a basic thin cheapie surround. The reason it needs to be trimmed is because it is on a slant wall, and is about 3 in too tall.
What should I use to trim it? |
I have used the white PVC 2-1/4" trim from Lowes at times. Plastic so it will not rot.
Okay, maybe I phrased it wrong.
I need to cut it down. It is 3 in too tall. |
My bad, ok, use a very sharp new razor knife blade. Lay a straight edge across the line you want to cut and score it several times. I it is one of those flimsy thin Lowes specials this should work. Just make sure the surround is at room temp and not cold. If the pannels are not flat, but rather contoured, then I would try a grinder with one of those real thin metal cutting blades and go ever so slow.
Ya, its flat... and pretty thin. Although, the corners have shelves, and are somewhat rounded.
What about using a jig saw with a very fine blade, like one similar the ones for laminate countertop? |
If it's anything like formica, then apply tape along your cut line. I have not done this myself, I myself wold use a razor blade over a jigsaw.
okay. i'll try it with the razor knife.
thanks for the help! |
| All times are GMT -4. The time now is 10:04 AM. |
