Best Way To Plumb 2 Sinks? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-30-2012, 04:39 PM   #1
JOATMON
ddawg16's Avatar
Rewards Points: 818
Best Way to Plumb 2 Sinks?
I have an issue that I would like expert input on.
Upstairs in our master bath, we 'will' have 2 sinks. The Vanity area is L-shaped. In the below photo, the black ABS pipes sticking up represent the apx location the sinks will be. I have the vent pipe already installed....you can see it sticking down...the black pipe that is clamped horz is 'about' where I would run the vent line for that sink.
Part of my problem....below that vent pipe is a nice large 7x12 PSL beam....
So...my down line has to be on either side of it....
The sink on the left is easy....I can drill through the bottom plate and run the drain pipe between floor joists....
Other sink is not so easy....that outside wall has a 4x12 PSL beam under it....I'm not going to be drilling in it. Because everything will be hiden by the lower cabinet....I was thinking of just running the drain along the wall over to the corner and mergin with the other drain....
So the real question is....how far can I run a sink drain more or less horz over to anther sink?
Old 09-30-2012, 05:18 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 350
Short answer- a 1.5" trap arm can be 42" from the vent to the weir of the trap.(UPC)
Have you considered going through the floor at the back of the vanity- before the beam, then 45 offset into the wall? The vanity toe kick should hide it
The Following User Says Thank You to TheEplumber For This Useful Post:
Alan (09-30-2012)
Old 09-30-2012, 07:20 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 818
Using the space below the toe kick? Handn't thought of that....
Considering the typical toe kick is 3.5" high....(I usually make mine 4")...figure 3/4" for the bottom shelf of the vanity....1.5" for the ABS....that gives me 2" for slope....at 1/4"/ft....that gives me plenty of room.....
My other option was to build a soffet on the back side where the vanity would be....but your option sounds better...
Thanks for the input
Having difficulty getting plumb cut for shed roof rafters humberguy Building & Construction 11 05-11-2012 11:32 PM
Problem with drainage in two new vessel sinks jpmain Plumbing 7 06-11-2010 01:17 PM
Repairing Out of Plumb Non-Flat Walls Tom5151 Building & Construction 1 12-01-2009 01:48 PM
PreHung exterior door into a not plumb opening fark Remodeling 2 10-29-2009 06:46 PM
How would I fix/re-do my sink's drain <leaking> piping? joeyboy Plumbing 17 12-18-2007 06:23 PM
