Old 01-31-2010, 12:35 AM   #1
the best way to piping baseboard water heating
I have to piping a multi base board heating two, or three tier element.. tubing,, my question is should I just put one termostactic valve, to control all of them or I have to put three of them in each tubing... thank you
alan25 is offline   Reply With Quote
Old 01-31-2010, 09:05 AM   #2
You don't need more than one thermostatic valve per room.
You can actually put this anywhere in the room (where the pipes if more than one converge and then re-diverge) you choose provided there is just one heating feed pipe entering the room and one return pipe leaving the room.
Note: If the return pipe leaving one room becomes the feed pipe for the next room, etc. then there should be no more than one thermostatic valve in the entire loop.
There are a few systems where the feed pipe splits into a "passing lane" with no finned pipes to the next room and a "travel lane" that feeds the finned pipes in the baseboards. The two pipes reconverge just before entering the next room. Here each room can have a thermostatic valve in the "travel lane".
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Why do water heaters have two elements? gp_wa Plumbing 21 02-09-2012 02:56 PM
Hot Water Baseboard Heating Issues hivicks HVAC 10 01-04-2010 07:27 PM
Repositioning Hot Water Baseboard Piping JPM HVAC 2 11-20-2009 09:08 AM
hot water heating and water heater raineywillow HVAC 1 12-24-2008 03:49 PM
hot water and central heating wont work independently khanay Plumbing 2 07-12-2008 04:14 PM
