Best Way To Hook Up Dishwasher Hot Water? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-20-2009, 12:23 PM   #1
Rewards Points: 278
Best way to hook up dishwasher hot water?
I have a Bosch dishwasher and I have 3/8" compression outlet ready to go.
Should I trust and buy the generic SS braided lines that has the rubber compression seal? (I call them fake compression) The DW side uses a pipe thread I think.
I was thinking about 3/8" copper tubing but I am afraid to put stress on the shut off valve (vibration from the dishwasher, maybe)
DIYGST is offline   Reply With Quote
Old 01-21-2009, 06:39 AM   #2
The braided dishwasher line kits have all the fittings needed, and work just fine. Soft copper is hard to bend without kinks and more work if service is needed.
Old 01-21-2009, 07:32 AM   #3
The DW should have a 90 on it that goes from pipe to compression. The braided hose will be fine.
jerryh3 is offline   Reply With Quote
Old 01-22-2009, 09:40 PM   #4
fake compress you not a plumber....but i understand braidet supply line is the way to go ..ever hear of flood safe supple line....do your researer burppp
drunknmaster is offline   Reply With Quote
Old 01-23-2009, 05:04 AM   #5
Yes. Well said.
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
Main Supply Line Vibrates When Cold Water Runs kmcbee1971 Plumbing 1 01-13-2009 09:26 PM
Dishwasher - top rack no water pressure jbomber Appliances 5 12-18-2006 04:49 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
