#1 |
Best way to fix a broken sewer cap?
With this picture you will see a broken sewer cap. This was underneath a horribly built deck that the last home owner installed. Apparently something smashed through the plastic hub and the metal cap. There is also a fair amount of rust. What is the best way to go about repairing this? It was suggested to me to use a pvc sewer cap, and a Fernco rubber cap. But I would like a second opinion on the matter. Thanks!
#2 |
i would dig down a little, to see what you have to work with.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. i didn't make this world. i just live in it. be careful of whom you make fun of. one day, that could be you... |
#3 |
That looks like a hub not just the pipe. You would have to remove that PVC dig out some dirt and use a chain cutter to snap it off in order to fit a hub less connector.
That also looks like SCH. 20 not SCH 40 PVC, toss it and get a new piece of SCH 40 a threaded adaptor and a threaded plug. http://www.bing.com/images/search?q=...5210&first=145 Last edited by joecaption; 09-04-2012 at 10:22 PM. |
#4 |
call me E
Simplest way- put a expandable "dollar plug" in the pipe and a PVC cleanout adapter and plug on the plastic riser
When posting in forums, letting us know your location will help others give better feedback/advice/solutions to your questions |
#5 |
Look at that PVC riser, looks to thin, and notice what looks like a seam in the bottom right, plus all the chips. Hard to do that with SCH 40.
#6 | |
call me E
Best way to fix a broken sewer cap?Quote:
Granted the best approach is to dig it up and see whats all there. I was only suggesting a simple, cheap yet functional repair.
#7 | |
"I second that."
No Warranty Means- If it breaks in half you get to keep both halves. |
| Display Modes | |
| How to avoid sewer problems or gain the upper hand in a home purchase | LateralConcepts | How To Guides | 0 | 02-01-2011 12:10 PM |
| broken sewer pipes with belly | chatty | Plumbing | 1 | 07-30-2010 10:31 PM |
| Broken clay(?) sewer line | zazz | Plumbing | 8 | 02-15-2010 11:12 PM |
| Broken, busted, clogged storm sewer line... | Upstate Steve | Plumbing | 1 | 04-07-2009 12:26 PM |
| Sewer gas smell in basement from sump pump | mirage212 | Plumbing | 15 | 10-23-2008 07:09 PM |
