-   -   Best way to fix a broken sewer cap? (http://www.diychatroom.com/f7/best-way-fix-broken-sewer-cap-155798/)
hamscam 09-04-2012 09:56 AM
1 Attachment(s)
With this picture you will see a broken sewer cap. This was underneath a horribly built deck that the last home owner installed. Apparently something smashed through the plastic hub and the metal cap. There is also a fair amount of rust. What is the best way to go about repairing this? It was suggested to me to use a pvc sewer cap, and a Fernco rubber cap. But I would like a second opinion on the matter. Thanks!
Fix'n it 09-04-2012 09:12 PM
i would dig down a little, to see what you have to work with.
joecaption 09-04-2012 09:17 PM
That looks like a hub not just the pipe. You would have to remove that PVC dig out some dirt and use a chain cutter to snap it off in order to fit a hub less connector.
That also looks like SCH. 20 not SCH 40 PVC, toss it and get a new piece of SCH 40 a threaded adaptor and a threaded plug.
http://www.bing.com/images/search?q=...5210&first=145
TheEplumber 09-04-2012 09:28 PM
199 Attachment(s)
Simplest way- put a expandable "dollar plug" in the pipe and a PVC cleanout adapter and plug on the plastic riser
joecaption 09-04-2012 09:34 PM
Look at that PVC riser, looks to thin, and notice what looks like a seam in the bottom right, plus all the chips. Hard to do that with SCH 40.
TheEplumber 09-04-2012 09:43 PM
199 Attachment(s)
It's prolly 3034 pvc- very common in my parts. used by municipalities and contractors for side sewers/laterals.
Granted the best approach is to dig it up and see whats all there.
I was only suggesting a simple, cheap yet functional repair.
COLDIRON 09-05-2012 06:54 AM
"I second that."
