Best Way To Cut Galvanized Drain Pipe? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-26-2010, 03:42 PM   #1
Rewards Points: 199
Best way to cut galvanized drain pipe?
I have a house built in 1972. I had a home inspection before I purchased but I guess the inspector wasn't very interested in plumbing. I'm missing a shutoff valve in the kitchen and already had to replace the toilet. Under the bathroom sink there is the original P trap which seems to be 2" galvanized steel. The former owners attached ANOTHER PVC P trap above it I suppose to help drain of new vanity reach the old drain. It clogs constantly. I want to cut out old drain pipe so I have a 4" stub to attach new PVC trap to. I just called a local plumber and he's talking about late next week before he can look at it and says he "needs" to cut out ALL the galvy in the house. I have a reciprocating saw and a dremel multi master and a few other tools. What's the best for cutting the pipe? Should I rent something?
Arlo is offline   Reply With Quote
Old 08-26-2010, 04:00 PM   #2
fabrk8r
fabrk8r's Avatar
I don't know if I'd cut it all out until I was sure it was necessary. Even if you do decide to remove it all there won't be a need to cut every joint. If there are ground-joint unions in any sections to be removed you won't have to cut there at all.
Once you open a couple pieces up you'll know if you need to remove it all. I would use a 4-1/2" grinder with a cut off wheel for any necessary cuts. It's quick, but it's noisy. Wear hearing and eye protection!
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 08-26-2010, 04:22 PM   #3
Rewards Points: 199
Thanks for the reply. I do have a grinder that's seldom used as I hate how stuff flies around from it. The plumbing seems to function so I don't want to cut it all out! I just wanted to take out the extra P trap. It looks terrible and constantly gets clogged. I can't believe the inspector didn't notice it. Replacing all the plumbing seems a bit extreme. He must have boat payment due!
Old 08-26-2010, 04:44 PM   #4
sawzall and a metal cutting blade. If you can cut where there are threads now it will start easier and cut quicker. Use a nohub coupling to attach new ABS/PVC and go nuts
the_man is offline   Reply With Quote
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 06:38 AM
Drain Pipe about 20 Inches to the right of Vanity Sink mark2741 Plumbing 2 12-16-2009 10:32 AM
Leaking kitchen sink drain pipe zasior Plumbing 10 01-11-2009 07:22 PM
Drain Pipe MrMrsSip Plumbing 2 11-21-2008 05:46 PM
washer drain pipe paydelady Plumbing 3 11-13-2007 12:27 AM
