Best Way To Cut Cinch Clamp On Pex? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-11-2008, 07:20 AM   #1
Rewards Points: 150
Best way to cut cinch clamp on Pex?
I am trying to remove Stainless Steel Cinch Clamps on a few fittings on PEX. I have tried side cutters but they can't do it. I can cut them off with a dremel but I can't get it into all of the places I need to. Any other ways to get them off.
twilightcall is offline   Reply With Quote
Old 08-11-2008, 09:37 AM   #2
Registered User
Termite's Avatar
Yes, they make a tool to cut them off. I have one that is made by Zurn. It looks like a scaled down version of the crimping tool. One jaw goes into the throat of the fitting, the other jaw has a cutter on it that splits the ring.
The PEX tubing itself must be cut close to the fitting first.
Backing off OLD galvanizd pipe...& PVC to cast iron michael76 Plumbing 13 02-18-2009 12:18 AM
Clamp Pipe to 2x4 virdicyer Plumbing 35 08-08-2008 10:53 PM
Can't Decide Wirsbo or SS Clamp Style PEX? twilightcall Plumbing 1 02-09-2008 10:11 AM
Decided on PEX Should I use Clamp or Expansion? twilightcall Plumbing 4 01-31-2008 09:07 AM
Clamp on Amp Tester Help stagger19 Electrical 3 03-07-2007 09:26 PM
