-   -   Best Way to Cap Rough-In Valve? (http://www.diychatroom.com/f7/best-way-cap-rough-valve-159072/)
ddawg16 10-05-2012 02:55 PM
I just received my Delta rough in shower valves....in retrospect, I should have bought the version without the outlet for a tub spout.
So....how do you guys plug them?
It's threaded....but since I don't ever plan on converting a shower to a tub....it will never need the tub spout.
Do they make plugs the same size (OD) as 1/2" copper pipe?
Or do you just shove a short piece of copper pipe in there and sweat on a cap?
TheEplumber 10-05-2012 03:27 PM
199 Attachment(s)
Use a 1/2" brass plug - 1/2" copper x male adapter, pipe and cap
Sent from my iPhone using DIY Forum
ben's plumbing 10-05-2012 05:55 PM
yep do what the plumbers say:laughing::laughing:ben sr
ddawg16 10-05-2012 06:45 PM
Ok....you need to translate that to non-plumber language....
If I understand this correctly...sweat in short piece of 1/2 pipe...then sweat a cap on that?
TheEplumber 10-05-2012 06:53 PM
199 Attachment(s)
My bad- or should I blame it on my iphone :)
If the valve has female threaded connections, screw a 1/2" brass male iron pipe plug into the tub port.
Or you can make a plug with a male IP adapter, piece of copper pipe a couple inches long and a copper cap. Sweat the pieces together, let cool then screw into the port. Use tape and dope of course.:)
